Can't add existing mp4 movies to Movies library
I’m running RasberryPi OS 11 (Debian) on an 8 GB Pi4B.
I have my Movie files on /media/mypi/transfer/l/Movies
with subdirectories for Comedy, Disney, Drama, Musical
etc. I added to the Movie main the /media/mypi/transfer/l/Movies.
mypi is the userid and pi8 is hostname. I added mypi to the
group plex and changed the perms for …/l/Movie/Comedy/
to 775 and ownership to mypi:plex. I thought that pointing the Movie
library at the local mount point to the directory and giving it rwx access
should let it find the file formatted as suggested.
Plex does see the server.
What am I doing wrong?
Filesystems which are automatically mounted under /media/username (by udisks2) have ACLs applied to them; these trump any perms you set with chmod.
It’s recommended to create static mounts for your disks using the information in this how-to:
You could also try the following. This will modify the ACLs associated with /media/mypi/ to include user plex with read/execute permissions.
sudo setfacl -m u:plex:rx /media/mypi/
