Can't add items to home on Uno
The uno UI by default chose the wrong server to play from, was pulling from my grownup server to my kids Apple TV.
Unpinned, and pinned all the correct server info, Couldn’t find a way to change it in the home screen so deleted them - now there is no way to add them back to the home screen.
Maybe I’m missing something but from what I can see 2 bugs
  1. no way to change the main server, with out removing, all channels and adding the correct ones.
  2. deleting stuff from the home screen has no way to get it back
At the bottom of the home screen, you can select reset settings or something similar, that will help you restart from scratch.
To add new content to the home screen you actually go to the recommended screen of your TV shows Library or your movies Library and scroll to the bottom of that screen, and then click on manage hubs. That will let you select which one of those rows on that recommended screen that you want to add to your home screen.
Thanks - didn’t see that.
I feel like the “reset” wasn’t there when I was first looking - didn’t see any buttons at all, because I was trying to reset it. Maybe I just missed it.
It would be nice to have the 3 dot ellipsis next to home - and say manage hubs there so you see the terminology associated with the home section.
Would also be nice to have the option in the 3 dot to switch the server its pulling from, or something like choose a new library.
Thanks Again,
Nathan
