Hello, I recently setup a new HTPC and cannot seem to edit the Home Screen. I’ve tried restoring to default numerous times. All that will show is : 1) Podcats and 2) Webshows (Plex content). I’d prefer my own libraries (movies, etc). But, nothing shows up in the edit dialog. Here’s a screenshot:
I saw another user with this similar issue and the suggestion was to “add library to home” but they didn’t indicate how that’s done. I can’t seem to stumble over the correct area where that is toggled. Please, if someone could assist? TIA
Yea, I just happened to be looking at the hosted app and remembered the sequence. I also remember thinking ‘why - when my server is the only one - must I do this’?
I also thought I can’t be the only one that doesn’t find this all that ‘intuitive’ and, look, here we are…
Settings - Web Client - General - ‘Show Advanced’ - “Reset Customization”
will invoke the setup wizard again and allows you to populate both the side bar and the home screen with items from a selectable preferred server.
This wizard had a bug, which prevented it from appearing for users which have only one server and disabled also all Online Media sources in their account.
Make sure you use the hosted web app when you invoke it, so you are running the latest code: app.plex.tv
hey there, the suggestion below by the moderator ultimately reset my Home and fixed my issues. However, what you’ve suggested was working until the reset. Thank you for pointing out the + in the recommended area. That is not something I’ve noticed before and did in fact add a section to Home prior to the reset procedure. Cheers!
