Can't Add TV Show Library
Hi
I have a ReadyNAS 104, and using Plex 1.5.6.3790
I have had no issues adding movie and music libraries but every time I try to add a TV Show library, I get the message “your changes could not be saved” and I am unable to add it. The folder I have my TV shows in is set out as required by Plex and has even been used with Plex before without issue. Just to check it’s not a permission issue I tried adding the TV Shows as a movie library and it had no problems adding them but obviously it did not lay them out in a useable way. Is there something I’m missing here? I really need this up and running. Thanks.
Solved the problem by enabling local media assets in the agents setting.
Where did you find that setting?
https://support.plex.tv/articles/200220677-local-media-assets-movies/
It didn’t help me… it was on, tried to turn it off then on again, didn’t work… the “local media assets” is in first position also.
