Server Version#: 1.19.4.2893
Player Version#: NA
Hello. I Just installed Plex server into a Synology hosted by Infomaniak
but once I open the remoteIP:32400/web and login with my Plex Account
I just receive a message : Sorry no soup for you.
Tried to disconnect and reconnect.
Restart the Plex server.
Connect to VPN synology.
Nothing is working.
I also tried a SSH tunnel but once I try to connect to localhost tunnel, the page don’t come out.
Help !
SSH tunnel is the way to go, you have to be on the same local network (subnet) to claim the server.
This is the problem.
How can I be on the same subnet, if I procceed the claim from another network ???
Via SSH tunnel if you do it properly
Scroll down to “On a different network”
I tried wit Putty
Session :
RemoteHostIP:22
Connection: SSH: Tunel : Source port: 8888
Destination : localhost:32400
Open the connection, windows logon and I log with my Synology admin
then tried to open localhost:32400/web
is not working
Other way round I guess. 32400 source, 8888 destination, no?
Then you open localhost:8888
Not sure about the first part (switched source and dest) but definitely sure about the second. This is also what the guide says.
help said:
Gateway : ip.address.of.server (here the Remote server IP)
Source Port : 8888
Destination : localhost:32400 (don’t know if I must leave localhost or put my desktop IP)
Once you have the SSH tunnel set up:
- Open a browser window
- Type
http://localhost:8888/web into the address bar
Obviously not what you did
just tried to open http://localhost:8888/web
and it’s not working
so I tried with a terminal console and apparently “localhost” can’t be resolved by the remote server.
@ChuckPa
I there another way to claim this server ?
xml.pref ?
Token to handle with ssh terminal ?
All my procedures specifically state: 127.0.0.1
I am mandating the use of the IPv4 loopback interface.
Which version of DSM are you using?
I just tried here locally and see even worse.
[chuck@lizum ~.501]$ ssh -l admin -L 8888:127.0.0.1:32400 192.168.0.23
admin@192.168.0.23's password:
admin@moesern:~$ hostname
moesern
admin@moesern:~$ uname
Linux
admin@moesern:~$ uname -a
Linux moesern 3.10.105 #25426 SMP Tue May 12 04:51:33 CST 2020 x86_64 GNU/Linux synology_avoton_1815+
admin@moesern:~$ channel 3: open failed: connect failed: Connection refused
channel 4: open failed: connect failed: Connection refused
This is something new with DSM’s most recent updates.
I will investigate and report back
UPDATE:
- DS418j - works as expected with SSH-tunnel
- DS1815+ - rejects SSH-tunnel
- Ticket created with Synology ( “+” models are different)
RS820+ with DSM 6.2.3-25426
Any news from Synology about this issue ?
