Can't connect to PMS running in MacOS Big Sur
Server Version#: 1.20.1.3252
Player Version#: iOS 7.6.1
I have PMS installed in 2 Mac computers in the same network. One of the computers has macOS Catalina 10.15.7 and the other one has macOS Big Sur latest beta (launched today) which is not working showing as Offline as shown in the screenshot.
I don’t know if I’m missing anything but I have uninstalled everything and installed from scratch but it simply does not work.
Any ideas?
Thanks,
Same problem
Works for me!
Are you logged in to a Plex account on the iPhone?
(Or have you configured that PMS to allow connections without authentication?)
Are any Libraries on the iMac PMS shared with your user? That’s the same message you get if no Libraries or Media are shared with you from the server.
A friend had a weird experience earlier where an iOS app didn’t prompt for Local Network access. I’ve seen iOS fail to prompt for privileges when apps were updated before. However, since you can see the other local server, I doubt that’s the issue.
I have the setting correct also. I can get it to work only when I set the server setting for encryption to Preferred. The setting of Required fails. This scares me to think that the client is not connected with encryption.
Perhaps see if it is related to Required?
I just changed to “Required”, saved, connected, played.
Changed to “Disabled”, saved, connected, played.
Changed back to “Preferred”, saved, connected, played.
@TheBrac I assume you’ve restarted PMS? That can help it fetch/refresh certificates if that’s where the problem lies.
Might be worth sharing logs.
Tried that but restarted Plex every time when changing. On Required it doesn’t work. I will look to share my logs.
I’m like 90% sure it doesn’t need a restart for that one setting, but … sounds like you did restart plenty. :slight_smile:
I just tried restarting PMS after changing it to “Required” again, just in case. And it does still work for me.
Ok so I have restarted on setting both settings and only “Preferred” works. Which logs specifically are you looking for?
Here is my log.Plex Media Server.log (129.2 KB)
I think your PMS wasn’t able to get a certificate from the Plex cloud - and I don’t think the problem is on your end.
This is it saying “I don’t have a cert, and I’m trying to get one, and the server said ‘not found’”:
Oct 01, 2020 08:55:38.874 [0x700005e8b000] DEBUG - CERT: Certificate or intermediate did not exist, fetching a new one.
Oct 01, 2020 08:55:38.874 [0x700005e8b000] DEBUG - HTTP requesting POST https://plex.tv/devices/77b556967cbec011c1cf1499f440eb7910001d8f/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 01, 2020 08:55:40.054 [0x700005e8b000] DEBUG - HTTP 404 response from POST https://plex.tv/devices/77b556967cbec011c1cf1499f440eb7910001d8f/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 01, 2020 08:55:40.054 [0x700005e8b000] ERROR - CERT: Could not fetch certificate from the cloud: 404
This is you changing the setting to require secure connections:
[uri]=http://192.168.2.200:32400&httpsEnabled=0&httpsRequired=1&dnsRebindingProtection=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Which means of course your connection attempts now fail:
Oct 01, 2020 08:55:49.270 [0x7000065b5000] DEBUG - Request: [192.168.2.145:49763] rejected because secure connections are required
Oct 01, 2020 08:55:49.270 [0x7000065b5000] DEBUG - Request: [192.168.2.145:49764] rejected because secure connections are required
Oct 01, 2020 08:55:49.422 [0x700006532000] DEBUG - Request: [192.168.2.145:49765] rejected because secure connections are required
Try restarting the PMS again. There is a note on the status page that a “slow response” issue has been resolved. Yesterday some folks were having trouble with movie matching being slow and not responding, and that seems to be fixed too.
Maybe this was part of the same problem and is also fixed.
Thanks for the reply… however the issue still persists… :cry:. Still shows Offline to the app.
It’s possible the error is still occurring. Others are posting about it.
Unable to fetch certficate from cloud - #9
@ChuckPa I saw on that thread that you sent PMs to other affects users. I think @TheBrac may be affected by the “Could not fetch certificate” issue too.
@TheBrac, look here. @ChuckPa updated with instructions in the other thread -
Thanks for the page, @Volts. I tried method 1 on the other thread and still get the same 404, so I dropped my server details there to hopefully get it force-evicted on Plex’s end. Here’s hoping it works for others.
Operations notified for:
  • ilboss
  • teh_iceberg
  • TheBrac
the logs will confirm certificate issue
  • Not having an existing cert.
  • The 404 while attempting to download a new cert
So do we just wait now for a confirmation that it is done?
Additionally, in my logs, I believe I pulled some information out of the logs that identify me. TheBrac is definitely my username, but just wondering if you need something more specific.
Yes. Just waiting for them to confirm the bad cert records have been flushed.
Good news.
  1. Certificates should be cleared.
  2. If not, please notify me here and tell me which server. They have also given me a tool to do this.
ChuckPa, still nothing. do you need mail or plex server name?
