Locked out of PMS the moment I set Secure Connections=Required
Server Version#: Latest Plex Pass
I’ve been trying to setup a new PMS instance and everytime I set Secure Connections to Required, I lose access to Server settings and I have to change the SecureConnections=0 to =1 in the Preferences.xml file away in order to regain access.
My router is pfSense and I have the following entry in my DNS Resolver:
server:
private-domain: "plex.direct"
What else could be causing this issue?
P.S. Running PMS in a docker on Unraid. I have Plex running in a docker also in Unraid also with pfSense in another site with no issues with regard to Secure Connections.
can I ask how you changed this setting I can’t get into mine Plex server because of this setting, I have another thread open about this.
Can I ask how you changed this setting I can’t get into mine Plex server because of this setting, I have another thread open about this.
What platform is your server running on?
If I may augment here?
The Preferences.xml field everyone is discussing is SecureConnections
The values for SecureConnections are:
  • 0 = Required
  • 1 = Preferred
  • 2 = Disabled
Plex is working on to resolve the issue
Yup, just saw that post. Thanks!
