Can't disable PlexGDM
I installed Plex Media Server and Plexconnect on HP Mini Server with NAS4Free. Server ip is 172.16.77.200, but external ip is other. My Apple TV not included in 172.16.77.200/24 network and must connect on external ip. I try to disable plexgdm and set external ip in setting, but nothing happens.
Here is my Settings.cfg (real ip changed to xxx)
[PlexConnect]
enable_plexgdm = False
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 91.208.xx.xxx
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
and what answer nslookup
Megabook:~ mgbrain$ nslookup trailers.apple.com 91.208.xx.xxx
Server: 91.208.xx.xxx
Address: 91.208.xx.xxx#53
Non-authoritative answer:
Address: 172.16.77.200
At the same time, plexconnect installed on my Home-PC with Windows 8 works right and all options in Setting.cfg works like wrote on manual.
Have you logged into myplex?
Does the plex media server have the ip range of plexconnect/ATV is it’s allowed networks for no authentication?
What is the ip_self reported as in the plexconnect.log?
This sounds like a complex non standard setup so the more information and the more precise that information is the more likely someone can help
You need to use local IP addresses.
If you run a local PlexConnect instance you do not have to have a local PMS if you sign into MyPlex.
Throw away the settings.cfg and use the default generated one on next clean shutdown.
