trailers unava. GDM not finding PMS, Self_ip looks wrong...
  • ATV3 5.2.1
  • ATV DNS set to 192.168.2.26
  • PlexConnect installed on MacMini 10.8.4 (IP:192.168.2.6)
  • The device and operating system (including version number) that PlexConnect is installed on:
  • PMS installed on above mac, OSX10.8.4 (IP:192.168.2.26)
  • Media is on NAS (PMS via other clients)
  • PlexConnect downloaded from Github today approx 17:00
  • settings.cfg file reads
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.2.26
port_webserver = 80
  • Log file attached
  • A detailed description of the issue (the clearer you can make this the better):
firewall is turned off (temp)
enable_plexgdm seems to fail, even though there are 2 PMS servers on the network
IP_self shows 10.5.2.66 which seems way wrong, but i don't figure where this is coming from?
IP of ATV is 192.168.2.25
error i'm getting is Trailers are unavailable etc...
i think i need to figure why IP_self is wrong, any ideas?
  • ATV3 5.2.1
[PlexConnect]
port_pms = 32400
loglevel = Normal
port_webserver = 80
  • Log file attached
You ATV DNS needs to be set to the machine running PlexConnect.
And there is no log file attached.
Hi Trudge,
thanks for the help, yup, the ATV DNS is set to the machine running PlexConnect (192.168.2.26)
log file... humm had it listed when posting, but gone...
pasted here http://pastebin.com/s1LxGAY1
Hi All,
so after trying to fix this doing all the normal complex stuff I've rebooted both the switch (24pt prosafe smart Gigabit switch) and the router (draytek 3200)
and now the self_ip correctly identifies itself, and all works fine even the enable_plexgdm, thus not needing to manually set the pms ip.
all good, works a treat thanks all.
