Can't disable ""up next"?
I don’t want an auto-populating “Up Next”. It’s never right about what I want to listen to next.
I can clear “Up Next” manually, but when I choose a track the next time, Plexamp uses some algorithm to re-populate it (it might be as simple as adding the other songs in the folder, I haven’t scrutinized it closely).
I have disabled autoplay in the Settings-Playback-Autoplay option.
If I want to listen to a playlist, I will create one.
I do not want a workaround, like creating a playlist with one song.
I would like the default behavior to be if I choose a solitary track, to just let me play it and then be done (unless I repeat it) without Plexamp subsequently creating the uncontrollable “Up Next” playlist for me.
How can this be achieved?
You can’t. Plexamp is designed to keep the music going.
Ah well, that’s a terrible bit of UI, first to presume that I want something to keep playing, and second, that somehow Plex’s algorithm would know what I want to listen to.
PlexAmp isn’t like Pandora or Spotify, I’m playing specific media I own. Even some streaming apps, e.g. Youtube Music, allow you to play a single track and then stop, if that’s what you elect.
At a minimum, there should be an option to stop after playing a track, like a sleep timer, but without needing to know the duration.
You can use Play Next from the context menu of each album / song – this will only add that particular item to the play queue (no playlists involved).
if you click the text of the now playing item, this should bring up a context menu from which you can schedule a sleep timer w/ various options – check it out.
when the music is stopped, and you want to play a single track, select Play Next instead of play. that will only queue that track.
