Server Version#: 1.24.0.4930
Player Version#: 4.63.0
I have the HDHomerun CONNECT 4K (bought during kickstarter). The stations in my area (Charlotte) recently started broadcasting using ASTC 3.0. On the My HDHomerun webpage they show as HEVC. For instance for the local FOX station I see 46.1 (HD) and 146.1(HEVC). On Plex, it sees the 146.1(HEVC) but won’t allow me to enable it. Any ideas?
I have this same issue, has there been any movement on this?
You can only have one or the other enabled at the same time in Plex in other words disable the HD then you can enable the HEVC.
but you won’t get sound in Plex as it dose not support AC4…
