I have tried multiple Plex versions including final as well beta builds 1.11.3.4803, 1.9.3.4290, 1.9.1.4272, 1.8.1.4140, 1.6.0.3720 and 1.4.0.3224 and Intel driver versions 19.17.10.4229(15.28.24), 19.17.10.4101(15.28.23) and 9.17.10.3347 without any luck. Handbrake is encoding fine with qsv enabled and Plex software works but hardware transcode fails.
I was hoping things would just work in the public release and this was pretty much the only reason why I purchased a Plex Pass
Thank you for mentioning Handbrake. It seems that you and I have different problems, as I installed Handbrake and it shows ‘QuickSync hardware not detected or enabled!’
This is the processor that I have:
I’ve looked in the BIOS and everything related to graphics is enabled. I am running Windows Server 2016 though. Could it not have the needed bits?
edit: The answer is sorta. Since it’s a server, I overlooked installing the graphics driver. I’ve since done that, and now Handbrake detects it. However, Plex still refuses to use it.
Yes, I think something to do with the security model not allowing access to GPU frame-buffer when the system is locked or headless.
i hope someone with Sandy Bridge can help us with OS/driver version specific details. I’m sure the preview folks had it running flawlessly on Sandy Bridge for it to make Plex’s minimum recommendation.
Okay, so this seems to indicate that there is something Plex can do at some point. Apparently if it’s used with DX11, services can use QuickSync. It seems that excludes Windows 7, but with mainstream support of 7 ending years ago, does that even matter?
I’m sure all this has been discussed in another thread though…
@OttoKerner said:
And yopu have a monitor connected?
What type of file are you playing? ( Plex XML info would help)
Oh I am trying to play this on a T420 with display. Example media info for an x265 file is given below but i have tried it on x264 files as well with no success.
Video Resolution 1080p
Duration 53:20
Bitrate 1699 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Audio Profile he-aac
Video Profile main 10
Part
Duration 53:51
File Earth 1.mkv
Size 648.37 MB
Container MKV
Codec HEVC
Bitrate 1699 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Color Range tv
Frame Rate 23.976 fps
Height 1080
Level 4.0
Profile main 10
Ref Frames 1
Width 1920
Codec AAC
Channels 5.1
Bitrate 197 kbps
Language English
Audio Channel Layout 5.1
Profile he-aac
Sampling Rate 48000 Hz
Codec ASS
Language English
View XML
F:\Media\Hindi\Tigre.mkv
Media
Duration 2:39:52
Bitrate 8553 kbps
Width 1920
Height 816
Aspect Ratio 2.35
Container MKV
Audio Profile dts
Video Profile high
Part
Duration 2:39:52
File Tigre.mkv
Size 9.55 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Bitrate 7017 kbps
Bit Depth 8
Chroma Location left
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 24 fps
Height 816
Level 4.1
Profile high
Ref Frames 3
Scan Type progressive
Title DDR
Width 1920
Codec DCA
Channels 5.1
Bitrate 1536 kbps
Language हिन्दी, हिंदी
Audio Channel Layout 5.1(side)
Profile dts
Title DDR
Codec SRT
Language English
Codec SRT
Language العربية
Codec SRT
Language bahasa Melayu, بهاس ملايو
Codec SRT
Language Bahasa Indonesia
Codec SRT
Language ไทย
Codec SRT
Language Español
Codec SRT
Language Français
Codec SRT
Language Nederlands
Codec SRT
Language Português
Codec SRT
Language Italiano
View XML
