Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
Apple TV 3 (Model A1427) running 7.2 (7512)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
10.0.4.2
The local IP address of the device that PlexConnect is installed on:
192.168.0.112
10.0.4.5
10.0.5.5
10.0.6.5
10.0.7.5
10.0.8.5
10.0.9.5
The device and operating system (including version number) that PlexConnect is installed on:
Server running Linux 3.16.0-30-generic (#40~14.04.1-Ubuntu SMP Thu Jan 15 17:43:14 UTC 2015)
The device and operating system (including version number) that the Plex media server (PMS) is installed on:
The Plex media server (PMS) version number you are running (do not put ‘latest’):
0.9.14.4.1556-a10e3c2
The local IP address of the device that the Plex media server (PMS) is installed on:
192.168.0.112
10.0.4.5
10.0.5.5
10.0.6.5
10.0.7.5
10.0.8.5
10.0.9.5
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup or a fork.
Github 06.12.2015 07:59 UTC+1
The contents of your ‘Settings.cfg’ file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
enable_plexgdm = False
ip_pms = 192.168.0.112
port_pms = 32400
enable_dnsserver = False
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = False
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = High
logpath = .
A detailed description of the issue (the clearer you can make this the better):
I start the Trailers app on aTV and I see the PlexConnect main interface. I can get a list of all my movies and TV Shows (all without posters). I can see and edit the Settings too. As soon as I open a detail page for a media entry I don’t get any information from PlexConnect to aTV anymore and I have to restart aTV to get it working again. And by working I mean “more or less” because no posters, no media detail page, etc.
Yes, I disabled PIN for my Plex account.
I only see one difference between the very first installation and every after that one.
After the first launch I always got “05:24:30 PlexAPI: Servers (local, plex.tv, MyPlex): 0” in console. After I logged into my Plex Account on the aTV PlexConnect settings the first time it always is “05:24:30 PlexAPI: Servers (local, plex.tv, MyPlex): 1” even without logging into my Plex Account on aTV Plex Connect. So even after completely purging PlexConnect and my Apple TV and reinstalling it, it still says “05:24:30 PlexAPI: Servers (local, plex.tv, MyPlex): 1” - and after logging in it says “05:24:30 PlexAPI: Servers (local, plex.tv, MyPlex): 2”.
Ok, I guess I found something that can cause the problems. I deleted the logfile and set loglevel to High, started PlexConnect and tried to view a media detail page.
Log has entries like this:
05:48:35 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/PMS(10.0.9.5:32400)/library/metadata/16024?includeExtras=1&PlexConnect=Movie_PrePlay&PlexConnectUDID=XXXXXXXXXXXX&PlexConnectATVName=Apple%20TV
My AppleTV has the IP 10.0.4.225 and in PlexConnect Settings.cfg I specified ip_pms = 192.168.0.112
Ok there is some serious bug in PlexConnect - or it’s actually not what as what it’s advertised as.
Since Plex itself doesn’t give a damn **** about different subnets (randomly choosing an IP address) I changed some settings.
My Linux server (on which PMS, PlexPy and PlexConnect is running) has the following IP addresses:
1. 192.168.0.112
2. 10.0.4.5
3. 10.0.5.5
4. 10.0.6.5
5. 10.0.7.5
6. 10.0.8.5
7. 10.0.9.5
PMS is listening and serving content on all of these IPs. I now added A entry for media.an3k.lan for each of these IPs and added https://media.an3k.lan:32400,http://media.an3k.lan:32400 to the CSA URLs field in PMS so that this DNS name is sent to clients and not an IP address which is most of the time wrong (because the Plex logic here is plain stupid).
After I did that I finally got images shown on my aTV for the three libraries I have (Movies, TV Shows and Music). Great. But now I don’t get any content listed when I open eg. Movies on the aTV.
07:40:07 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/PMS(media.an3k.lan:32400)/library/sections/1?PlexConnect=Plex_Movie_Scanner&PlexConnectUDID=XXXXXXXXXXXX&PlexConnectATVName=Apple%20TV
Because my aTV has the IP 10.0.4.225 and asks the DNS server located at 10.0.4.2 it gets “10.0.4.5” as an answer and Plex is right there.
So with the wrong IP address sent to aTV I don’t get images (except the PlexConnect one in Settings) but a list of all the media I have. With the correct IP address I do get images but no list of media.
On my aTV PlexConnect tells me that the Plex Media Server said there is no Content.
Ensure you post your ‘PlexConnect.log’ file to pastebin and post the link (‘PlexConnect.log’ is located in your PlexConnect folder). If possible, follow these steps to create a “more detailed fresh” one:
Logfile without CSA URLs set (I do get a list of all my media in all three libraries but no images and as soon as I want to open a detail view something crashes and I have to restart my Apple TV): /uploads/default/original/3X/7/3/73e5323c353108090b92f1bbf849cd80e4cb81da.log
Logfile with CSA URLs set (I do NOT get a list of all my media in all three libraries but all images): /uploads/default/original/3X/6/1/612b173ec0fdf217cf897eddf54b2e2932e59aac.log
