Plex Interface does not show up under trailers
  • ATV2 or ATV3?: ATV3
  • Your ATV firmware version (found under the ATV settings > general > about > Apple TV software): 5.2.1 (6025)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 10.0.0.1
  • The device and operating system (including version number) that PlexConnect is installed on: Mini Mac OSX 10.8.4
  • The local IP address of the device that PlexConnect is installed on: Ethernet 94.203.161.89, Wireless 10.0.0.2
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Mini Mac OSX 10.8.4
  • The local IP address of the device that the Plex media server (PMS) is installed on:Ethernet 94.203.161.89, Wireless 10.0.0.2
  • Where your media is stored (e.g. internal drive): External Hard Drive
  • The PlexConnect version number (or if using Github source then a time and date of download; look at the creation date of the folder): 06th June 1:42pm
  • A detailed description of the issue (the clearer you can make this the better):
When I click on Trailers App on apple tv, it still comes up with Trailers.  It doesn't show the Plex Interface.  I currently have DNS set to Wireless DNS, but I have also tried connecting Apple TV on ethernet and using the ethernet DNS.  It made no difference
  • A log file (currently this is the output in your terminal/cmd window - we are looking to generate a separate log file):
CraigMac:PlexConnect-XML_templates Home$ sudo ./PlexConnect.py
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect : Press ENTER to shut down.
PlexConnect : ***
PlexConnect : IP_self: 10.0.0.2
PlexGDM : ***
PlexGDM : looking up Plex Media Server
PlexGDM : ***
PlexGDM : servers discovered: 1
DNSServer : ***
DNSServer : Starting up.
DNSServer : intercept trailers.apple.com: 10.0.0.2
DNSServer : forward other to higher level DNS: 10.0.0.1
DNSServer : ***
WebServer : ***
WebServer : WebServer: Serving HTTP on 0.0.0.0 port 80.
WebServer : ***
I'm not a pro but I had the same issue. Try to set the DNS of your atv to 10.0.0.2
Thanks Kevin.  The only way to configure the DNS on the Apple TV is to put it back on ethernet, so I tried that and changed the DNS to 10.0.0.2, however it now just comes up saying "accessing trailers" and after a while says "Trailers is unavailable, try again later".  10.0.0.2 is the ip address of the wifi, all the instructions say to put the dns server in the settings.py file, the dns server on wireless is 10.0.0.1
aTV's DNS has to point to PlexConnect - in your case 10.0.0.2.
I have made this change but it now says Trailers is not available try again later.  Any idea what is causing this?
updated output from terminal
Password:
PlexConnect : ***
PlexConnect : ***
PlexGDM : ***
PlexGDM : ***
DNSServer : ***
DNSServer : forward other to higher level DNS: 10.0.0.2
DNSServer : ***
WebServer : ***
WebServer : ***
Is port 80 being used by another service? That's what happened on mine. It was conflicting with SABnzb so I had to change SABnzb's port number.
I am getting a little closer.  I took wifi out of the mix, so PlexConnect is now on IP 94.203.161.89.  I updated the settings.py to reference this IP and manually configured atv to have dns server of 94.203.161.89.
It now comes up with PlexConnect but says there is no response from the Plex Media Server.
Updated output from terminal
PlexConnect : ***
PlexConnect : ***
PlexConnect : IP_self: 94.203.161.89
PlexGDM : ***
PlexGDM : ***
PlexGDM : No servers discovered
DNSServer : ***
DNSServer : intercept trailers.apple.com: 94.203.161.89
DNSServer : forward other to higher level DNS: 94.203.161.89
DNSServer : ***
WebServer : ***
WebServer : ***
DNSServer : DNS request received!
DNSServer : Source: ('80.227.58.173', 60097)
DNSServer : Domain: trailers.apple.com
DNSServer : ***intercept request
DNSServer : -> DNS response: 94.203.161.89
WebServer : serving application.js
80.227.58.173 - - [07/Jun/2013 19:50:01] "GET /appletv/us/js/application.js HTTP/1.1" 200 -
DNSServer : Source: ('80.227.58.173', 57956)
DNSServer : Domain: ax.init.itunes.apple.com
DNSServer : ***forward request
WebServer : serving /Applications/PlexConnect-XML_templates/assets/plexconnect.xml
80.227.58.173 - - [07/Jun/2013 19:50:01] "GET /plexconnect.xml HTTP/1.1" 200 -
WebServer : serving .xml: /library/sections
DNSServer : Source: ('94.203.161.89', 49152)
XMLConverter : Unable to connect to 192.168.178.2:32400
Reason: timed out
XMLConverter : No Response from Plex Media Server
80.227.58.173 - - [07/Jun/2013 19:50:11] "GET /library/sections HTTP/1.1" 200 -
WebServer : serving .xml: /channels/all&PlexConnect=Channels
Reason: [Errno 61] Connection refused
80.227.58.173 - - [07/Jun/2013 19:50:11] "GET /channels/all&PlexConnect=Channels HTTP/1.1" 200 -
WebServer : serving /Applications/PlexConnect-XML_templates/assets/search.xml
80.227.58.173 - - [07/Jun/2013 19:50:11] "GET /search.xml HTTP/1.1" 200 -
WebServer : serving .xml: /&PlexConnect=Settings
Reason: timed out
80.227.58.173 - - [07/Jun/2013 19:50:21] "GET /&PlexConnect=Settings HTTP/1.1" 200 -
Problem Solved - Thanks guys for everyone's input.  I just had to restart my Plex Media Server after I had switched Wifi off and turned ethernet on.
ccocker,
Would you mind posting your settings.py file?  I'm running into the same issue, but it looks like you're using an external IP to your PlexMedia and PlexConnect server -- 94.203.161.89?  It's my understanding that it can/should be a local IP.  I'm close -- I'm getting PlexConnect listening on port 80 -- but, I don't see any traffic when I open Trailers on ATV3.
Thanks,
-Ken
Just out of curiosity. Why can't you change the DNS on the aTV when on wifi?
ccocker,
Thanks,
-Ken
I don't believe I am using an external ip.  I will attach my settings file to this post
ccocker,
Thanks,
-Ken
Ken,
I tried to upload the settings.py file but it says I am not permitted to upload this kind of file
When I go into ATV Network Settings there is no Configure DNS option.  this only appears when I am on an ethernet connection.  I assumed that was standard and it was not possible to change.  Is there another way to do it
Sure on firmware 5.2.1.
Go into settings/general/network/wifi/yourwifi configuration/ scroll down to configure dns. Select manual. Change DNS number to your plexconnect server and click done.
If you have the option to use hard wired though do so, it may save you a lot of other headaches.
