I'm trying to configure the certificate on Windows but it doesnt work as it says that it can't open the config file. I've attached an princtscreen of how it looks when I try to install the certificate through cmd.
Anyone that knows what the problem is and that can help me?
Alt-PrintScr to only copy the current window?
I mean... you could also just copy/paste the text content.
Anyways, do you run cmd with administrator privileges?
thanks for your reply.
The text content is accurate. Cause it works on my mac. But not on the PC. How can I check if CMD is opened with administrator privileges? I don't have password to log in into the Windows 7.
I also wonder over the issue with the Mac. When I turned it off and turned it on again, the Plex wasn't working, how do I start it again? Do I need to re do all the things with the certificate or is it enough starting up something?
Find "Cmd" executable, right-click, run as admin.
Certs are done just once.
It worked. But another problem came up. Apple TV looses connection with the wifi and everything is gone. I've tried to solve it and spend two days without any success.
I will know give the LG Media Link beta thing a try.
