cert.create.bat unable to add certificate
cert.create.bat only .pem file is create but empty and  for sure unable to add certificate in windows.
i follow all instruction. but in the cmd.exe it said  traillers.pem is not reconize. not found... and alot of error ? when i try to run cert.create.bat in c:\Cert
any help could be great
DId you install OpenSSL? (and the corect version?)
what are the errors you get? (These might help someone to assist you)
Where did you get the .bat from?
Did you use trhe Plexconnect WIKI?
The more information you provide the more likely someone can help, at the moment, its just left everyone wondering and askign lots of questions
i have windows 7 french so im not sure this screen from cmd could help?
i use
https://forums.plex.tv/topic/79540-windows-specific-instructions-for-creating-and-installing-the-ssl-cert/
for the cert.create
and im unable to make the certificate so im stop at this step
http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
If you have a Webserver you can install it without disconnecting your atv at all.
https://forums.plex.tv/topic/80779-install-trailerspem-from-appletv-using-a-webserver-on-osx/
Install the same cert on your atv and your PC. Think of the cert of a way to allow your atv and PC to communicate, like a key to unlock the plexconnect door :wink:
the problem is im unable to Generate the SSL Certificates for windows with the cert.create.bat on this
(https://forums.plex.tv/topic/79540-windows-specific-instructions-for-creating-and-installing-the-ssl-cert/)
im not sure how to use cmd with
C:\OpenSSL-Win32\bin\openssl.exe req -new -nodes -newkey rsa:2048 -out C:	railers.pem -keyout C:	railers.key -x509 -days 7300 -subj "/C=US/CN=trailers.apple.com" -config C:\OpenSSL-Win32\bin\openssl.cfg
i type this and not working
Yes French means I can’t help but if you translate it I might be able to offer assistance. (I would google translate it if but it’s too hard as it’s a screen print).
I would also say the thread you are using is a bit old (it creates a .der while .cer is what is used). However you are not even getting to This step.
I will ask again. Have you installed the correct version of OpenSSL?
Win32 OpenSSL v1.0.1e
translation
c:\cerrt.create
c:\Cert\c:\openssl-win32......\bin\openssl.cfg
the access path was not found
c:\Cert\..... railers.der
the access path was not found 1))c:\ trilers.pem
the specified file is not found
c:\Cert railers.der
'trailers.der" is not recognized as an internal or external command, operable programe or batch file
c:\Cert )type c:\ trailers.key
i have just re install openssl (maybe i had install thelite vers.) and now its working ! but im not stuck in iPhone Configuration Utility ... i click on the install button in ( atv.. configuration) and nothing  is made ! ... im not sure what to do
Use the network method instead to install the certificate on the ATV (see wiki guide).
not working with network method, trailer not avalaible  (my dns on atv is set at same ipself).
how to see if the cert is realy install on the atv3 ?
maybe that could help to help !
i think the profile i try to add is not working, http:\\ plexconnectmyipself19.186.0... railers.cer
i didnt see a new profile creat in atv
What is the IP of your PlexConnect machine?
Are you putting all the files in the PlexConnect certs folder?
What EXACTLY do you enter on the ATV to find the profile?
Any error message on the ATV when you try and add the profile?
192.168.0.249
yes
http:\\192.168.0.249 railers.cer
192.168.0.242 is my atv id
when i go in plex server,general, i have The path where local application data is stored and is C:\Users\rx 2\AppData\Local... its ok?
certificate picture
but i dont have trailers.cer file !
Open cmd prompt and create your files, make sure you run as administrator. Find the certificate and double click it to install it before opening iPhone configuration.
Oh, and place the pem file into the certificate folder of plex connect so it can find it
192.168.0.249
yes
Um your slashes are wrong, it should be:
http://192.168.0.249/trailers.cer
yes on the appletv is http://192.168.0.249/trailers.cer but i just make this mistake here.
certificate picture
It is hard to see what is there without windows showing the file extensions.
