As suggested by Frank, here’s a separate thread for the same issue on LG’s - LG cannot play AVI files
Given that they appear to be same issue on the surface, just different platforms, I’ve also posted a link to this thread in the new LG thread so it’s easy to cross-reference if needed.
Hi same AVI playback issue was reported in LG plex app and the latest LG WebOS version 5.6.1 contains “Fixed playback of AVI files”
The thread said the plex app was forcing an unneccessary transcode of AVI which would explain the issue I reported, as my DS216PLAY does not support hardware transcoding, has that fix been deployed in the Samsung app yet ?
I am still running 5.1.0 and AVI playback is working.
This is logfile if I play any AVI file that are used to be ok before something happened:
Mar 17, 2021 20:13:51.628 [0xb230f430] Debug — [Transcode] Found session GUID of aax3o9psezyi4s0u1ubrcnmi in session start.
Mar 17, 2021 20:13:51.630 [0xb230f430] Debug — [Transcode] TranscodeUniversalRequest: using augmented profile Generic
Mar 17, 2021 20:13:51.630 [0xb230f430] Debug — [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/100?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=trnvgk8d8ww070ce17kvp9zf
Mar 17, 2021 20:13:51.630 [0xb230f430] Debug — [Transcode] Auth: authenticated user 1 as XXXXXXXXXXX@gmail.com
Mar 17, 2021 20:13:51.648 [0xb230f430] Debug — [Transcode] We’re going to try to auto-select an audio stream for account 1.
Mar 17, 2021 20:13:51.648 [0xb230f430] Debug — [Transcode] Selecting best audio stream for part ID 104 (autoselect: 1 language: it)
Mar 17, 2021 20:13:51.648 [0xb230f430] Debug — [Transcode] Audio Stream: 281, Subtitle Stream: -1
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] Scaled up video bitrate to 1650Kbps based on 1.500000x fudge factor.
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Selected protocol dash; container: mp4
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: analyzing media item 100
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): Direct Play is disabled
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): media must be transcoded in order to use the dash protocol
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): no direct play video profile exists for http/avi/mpeg4
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): no direct play video profile exists for http/avi/mpeg4/mp3
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): Direct Streaming is disabled, so video stream will be transcoded
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): no remuxable profile found, so video stream will be transcoded
Mar 17, 2021 20:13:51.656 [0xb230f430] Debug — [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Mar 17, 2021 20:13:51.657 [0xb230f430] Debug — [Transcode] Scaled up video bitrate to 1650Kbps based on 1.500000x fudge factor.
Mar 17, 2021 20:13:51.657 [0xb230f430] Debug — [Transcode] MDE: Cannot direct stream audio stream due to codec mp3 when profile only allows aac
Mar 17, 2021 20:13:51.657 [0xb230f430] Debug — [Transcode] MDE: Non è un paese per vecchi (2007): selected media 0 / 100
Mar 17, 2021 20:13:51.657 [0xb230f430] Debug — [Transcode] Streaming Resource: Reached Decision id=100 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4002,Not enough CPU for conversion of this item.)
