Server Version#: 1.13.5.5332
Player Version#: 3.69.1
When I attempt to play TV shows they never start playing. I’ve checked the server and it never even launches the transcoder process. I’ve tried using a web player, the Windows 10 player and the android player and get the same result every time, playback never starts at all.
Settings - Server - Network - ‘Show Advanced’ - “IPv6 support” <-- DISABLE
Settings - Server - General - “Verbose Logging” <-- DISABLE
then restart Plex server
Side note:
Did you intentionally install Plex’s program files on drive D: ?
If so, this doesn’t do what you think it does.
To really save storage space, you need to move the Plex data folder, not the program folder.
The program folder is only 160 MB, the data folder can grow to Gigabytes.
So: your drive D: is it internal, external, network share or anything else?
