Can't put two libraries of the same show with different versions
Server Version#: 1.40.3.8555
Player Version#: tvOS 17.5.1
I have two versions of a show. One is dubbed in English, the other is the original Spanish. I used: Series (2024) [Dubbed] - S01E01 - Title 01. vs. Series (2024) [Spanish] - S01E01 - Title One. I found an earlier support document that suggested this naming structure. The author said that after scanning library files the shows would appear together. They would need to be split. However, PLEX isn’t giving me the option to split them. When I press the three dots, I can “analyze” and “match” the show, but I can’t “split.”. When I go into the “Season 1” library info, both versions are listed - Dubbed and Spanish - but as soon as I leave that window, PLEX forgets there are two versions. It displays the dubbed version, and that’s the show that plays - I assume because D comes before S in the dictionary. Any other suggestions? I tried putting dubbed in alone and matching it to a different show, then adding Spanish. But as soon as I scan the library, the two versions go right back down to one.
Please read the bottom line of this support article.
https://support.plex.tv/articles/multiple-editions/
Have you tried adding a Spanish Library
I haven’t, but I want them to appear next to each other. I don’t even speak Spanish, I just usually prefer to watch the movie or show in it’s original language with subs. Unless it’s late and I’m too tired to do all that reading. So I’d like to be able to switch.
Your reply made me think of something. What if I put the Spanish language version in it’s own folder, and then add the new folder to the library. I’ll try that tomorrow.
This is key to the above linked method.
In order for TV shows to even be able to split, they need to be in separate folder structures.
Don’t do that. You cannot add the folder of an individual show to a TV shows library.
See Question About Adding a Show With Two Versions of Every Episode - #2 by OttoKerner
OK, but I can create a folder called “Foreign Languages” or something, and point to that, right?
Have you looked into if these files will remux into a dual-audio release okay? If the timings are correct you can just take the version with the better video and mux the audio (and subs if needed) from the other release into it and have one set of files for the show.
Then you can edit the advanced settings for the show in your library and set the audio/subtitle preferences for your own viewing. The language prefs wouldn’t impact other users.
ONly top lever folder(s) for TV should added library settings. in my case in image it is called “testtv”
in that folder should be two different folders for each of the shows along with folders for all your other shows.
Show (2024) [Dubbed]/Season 01/Series (2024) [Dubbed] - S01E01 - Title 01.mkv
Show (2024) [Spanish]/Season 01/Series (2024) [Spanish] - S01E01 - Title 01.mkv
testtv
if you have them like that they will merged then you can split the shows apart at the show level and rename them however you want.
Plex
Yes you can.
