Server Version#: 1.19.4.2865
Player Version#:8.1.0.17967
When navigating the library and I pick a show - the menu defaults to play or add to playlist vs the expected behavior which would list the seasons and ALL available shows.
It looks like you long-press the icon of that show. That will indeed bring up a context menu that’ll allow you to directly start playback of the entire show (or where you left it off), adding it to a playlist etc.
A simple single click on the show item will open the show page instead.
(just double-checked on my Android TV)
this must be a new change as this problem didnt exist a week ago - i just confirmed that it works as youdescribe with the FireTV remote which I dont typically use - I have CEC turned on and had been successfully using the factory Samsung TV remote until now. This option needs some tweaking as I prefer the single remote solution.
