@trumpy81 said:
Plex no longer uses SSLv3 for sign in, this has been documented in the forums and various other places, which is basically what I have been trying to tell you, your version of PMS will no longer work. You can bang your head against the wall all you like, but it wont change anything.
Upgrading your NAS is not the only advice I gave you, but you seem to have chosen to ignore that, I’m sorry, I wish things were different, but I don’t have a magic wand to fix it for you. I can only tell you how things are, what you do with that information is up to you.
If you are a Linux/programming guru, then by all means keep trying to fix the issue, I’m sure there would be others who would appreciate your ‘fix’, but until then, there is nothing anyone can do for you.
Well, now, I have a real answer: “Plex no longer uses SSLv3 for sign in”… And no, this was not what you were telling me! Yes, I am IT, and therefore being given a “your device is no longer supported” simply doesn’t suit me. As it turns out, yes Plex DID, in fact, change their authentication method on their website, as I expected! Seems to me like it’s now using TLSv1, and has turned off SSLv3! Bummer …
If you knew this, trumpy81, you simply could have said this instead of all this talk for nothing. Otherwise, one like myself, just assumes Plex decided to longer offer old versions for downloads. You cannot go and just say “you’re no longer supported”, or if you do, well complement the answer by adding “therefore removed the older authentication method, and that is why you cannot login…”.
As for your other advice, I haven’t ignored them. The thing is, I do not have a tower running Linux/Windows/Whatever on which I could install the latest Plex server. I’d love too, but sh**t me, I left my old towers back in Canada 3 years ago when moving to Europe. All I’ve got with me now is my good old NAS, my MAC laptop, and a PlayStation3… (apparently, sucks to be me I guess). So, seems like you were advising to either throw in money for a new tower running Linux or whatever, or upgrading my NAS. Comes down to that
All that login problems being said, I still wonder: what client DID connect to PMS0.9.x still? Perhaps I could find a version that would connect to it, IF we can connect to it WITHOUT internet / without having to authenticate to the Plex.tv website. Now, I believe the latter should be possible, no? I did see an option in the Plex: “Settings / Server / Network: List of networks that are allowed without auth”. Just guessing this would be it, no? If not, and if I’m told Plex HAS to sign into the website to play your own, local media, then, I raise my middle finger to Plex, cause that would just be plain stupid: what if you’re internet provider is down? Can’t watch your movies?
Thanks for any help regarding this last point.
Regards, Pat
