About to Give Up on Plex
I am a lifetime member on Plex and for years I’ve struggled to make this system work on Ubuntu. The support is convoluted at best and often times useless. I get Plex working and then it just stops or crashes or some videos that were working one day stop working.
This is TOO much work and I don’t think it’s really a viable application, in its current form, for everyday use. My computer has everything to make this work but after years of screwing around with this application and to have it fail randomly is just too much. I can no longer recommend Plex Media Server.
My system:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 21.04
Release: 21.04
Codename: hirsute
System Info:
System:
Host: linux-box Kernel: 5.11.0-34-lowlatency x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Ubuntu 21.04 (Hirsute Hippo)
Machine:
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
serial:
Mobo: Gigabyte model: X570 AORUS ELITE WIFI v: x.x
serial: UEFI: American Megatrends LLC. v: F34
date: 06/10/2021
CPU:
Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP
L2 cache: 3 MiB
Speed: 3611 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 3611 2: 4523
3: 3617 4: 4522 5: 3616 6: 4523 7: 3610 8: 4508 9: 3617 10: 4521 11: 3613
12: 4520
Graphics:
Device-1: NVIDIA GK208B [GeForce GT 710] driver: nvidia v: 460.91.03
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 2560x1440
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.91.03
Audio:
Device-1: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.11.0-34-lowlatency
Network:
Device-1: Intel Wireless-AC 9260 driver: iwlwifi
IF: wlp3s0 state: down mac: 98:8d:46:87:fb:31
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: 18:c0:4d:80:13:23
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
IF-ID-1: docker0 state: down mac: 02:42:8e:f0:9c:35
IF-ID-2: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth:
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
Report: ID: hci0 state: up running pscan bt-v: 3.0
address: 98:8D:46:87:FB:35
Drives:
Local Storage: total: 28.42 TiB used: 11.46 TiB (40.3%)
ID-1: /dev/sda type: USB model: TO Exter nal USB 3.0 size: 2.73 TiB
ID-2: /dev/sdb vendor: Seagate model: ST8000NM0105 size: 7.28 TiB
ID-3: /dev/sdc vendor: Western Digital model: WD30EZRX-00SPEB0
ID-4: /dev/sdd vendor: Seagate model: ST8000NM0105 size: 7.28 TiB
ID-5: /dev/sde vendor: Patriot model: Blaze SSD ATA Device
ID-6: /dev/sdf vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
ID-7: /dev/sdg vendor: Seagate model: ST8000DM004-2CX188 size: 7.28 TiB
Partition:
ID-1: / size: 915.4 GiB used: 280.6 GiB (30.7%) fs: ext4 dev: /dev/sdf2
ID-2: /boot/efi size: 511 MiB used: 15.3 MiB (3.0%) fs: vfat
dev: /dev/sdf1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 36.5 MiB (1.8%) file: /swapfile
Sensors:
System Temperatures: cpu: 82.4 C mobo: 16.8 C gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A
Info:
Processes: 543 Uptime: 6d 14h 02m Memory: 31.36 GiB
used: 12.36 GiB (39.4%) Shell: Bash inxi: 3.3.01
I can probably get you up, running, and stable.
I’m not sure, given your frustration, if you wish to continue that or not. I see the forum has your last original post as of 2018. A great deal has changed since then.
I’ve been here in the forum , providing support wherever and whenever needed. Just asking in a “server-linux” tagged forum will always get my attention (I see every post)
May I see a df of how the file system is laid out? I don’t much need to know the lshw listing. How you wish you use the local resources for media doesn’t concern me as much as your system / partition and the amount of space you have to work there.
Did you install directly from Plex.tv/downloads or did you install via the ubuntu store?
As secondary post due to it’s importance ,
I spotted your server certificate was questionable since it was created prior to October first (new root certificates took over).
I have reset it.
Please restart the server.
df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 3288160 2064 3286096 1% /run
/dev/sdf2 959863856 295479808 615555840 33% /
tmpfs 16440800 632 16440168 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 4096 0 4096 0% /sys/fs/cgroup
/dev/sde1 229700940 86992768 130970316 40% /mnt/ata-Patriot_Blaze_SSD_ATA_Device_DE35074914EE00811960-part1
/dev/sdf1 523248 15652 507596 3% /boot/efi
/dev/sdd1 7751408932 3495487112 3865204176 48% /media/robert/LPhoto
/dev/sdg1 7751408932 4543355524 2817335764 62% /media/robert/System_BU
/dev/sdb1 7751408932 1989368400 5371322888 28% /media/robert/LSecondary
/dev/sdc2 2884152536 1164029328 1577227496 43% /media/robert/LStore
tmpfs 3288160 148 3288012 1% /run/user/1000
pCloud.fs 2684354560 178766664 2505587896 7% /home/robert/pCloudDrive
I just ran the following:
sudo systemctl restart plexmediaserver.service
Now when I connect to my server using plex.tv, this message appears: app.plex.tv is unable to connect to “linux-box” securely
This all was working and now it’s not. I can connect directly with my server if I use http://192.168.xx.xx:32400/web/index.html - but that’s not useful on my other media devices. No, none of my other permissions have changed.
What do you see under Settings → remote access ?
@bit.shifter52_gmail.com
Would you now please do the following:
  1. Stop Plex
  2. Wait 1 minute
  3. Start Plex
  4. Wait 2 minutes
  5. as root - make a tar.gz of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs
  6. Attach that tar.gz
linux-box.tar.gz (4.0 MB)
Your server is running and transcoding with the Nvidia perfectly.
What I’m seeing is the FireFox player choke.
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Oct 26, 2021 05:41:53.702 [0x7f3fb416fb38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Oct 26, 2021 05:41:53.738 [0x7f3fb416fb38] DEBUG - [Transcode] Scaled up video bitrate to 1579Kbps based on 1.500000x fudge factor.
Oct 26, 2021 05:41:53.738 [0x7f3fb416fb38] DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to codec mp3 when profile only allows aac
Oct 26, 2021 05:41:53.738 [0x7f3fb416fb38] DEBUG - [Transcode] MDE: How to Make It in America - S1 E1 - Pilot: selected media 0 / 11649
Oct 26, 2021 05:41:53.738 [0x7f3fb416fb38] DEBUG - [Transcode] Streaming Resource: Adding session 0x7f3fb3b81c48:pcdeqemblzvkxny9s55lmya4 which is using transcoder slot.  Used slots is now 1
Oct 26, 2021 05:41:53.738 [0x7f3fb416fb38] DEBUG - [Transcode] Streaming Resource: Added session 0x7f3fb3b81c48:pcdeqemblzvkxny9s55lmya4
Oct 26, 2021 05:41:53.739 [0x7f3fb416fb38] DEBUG - [Transcode] Streaming Resource: Reached Decision id=6105 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=11649 part=(id=11658 decision=transcode container=mp4 protocol=dash streams=(Video=(id=24498 decision=transcode bitrate=1579 encoder=h264_nvenc width=624 height=352) Audio=(id=24499 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000) Subtitle=(id=103722 decision=transcode bitrate=2147483647 encoder=ass languageCode=eng location=sidecar))))
Oct 26, 2021 05:41:53.739 [0x7f3fb416fb38] WARN - Caught exception trying to convert extra data attribute 'originallyAvailableAt' with type 1 and value '2010-02-14' ~ bad lexical cast: source type value could not be interpreted as target
Oct 26, 2021 05:41:53.739 [0x7f3fb44ceb38] DEBUG - Completed: [127.0.0.1:50598] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F6105&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=p8zpsrw905p2yy1aouwi5vvd&subtitles=auto&Accept-Language=en (18 live) GZIP 181ms 2290 bytes (pipelined: 28)
Oct 26, 2021 05:41:53.792 [0x7f3fb37d4b38] DEBUG - Request: [127.0.0.1:50598 (Loopback)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F6105&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=p8zpsrw905p2yy1aouwi5vvd&subtitles=auto&Accept-Language=en (18 live) GZIP Signed-in Token (bit.shifter52@gmail.com)
Oct 26, 2021 05:41:53.792 [0x7f3fb37d4b38] DEBUG - [Transcode] Found session GUID of p8zpsrw905p2yy1aouwi5vvd in session start.
Oct 26, 2021 05:41:53.792 [0x7f3fb37d4b38] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Firefox
Oct 26, 2021 05:41:53.792 [0x7f3fb37d4b38] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/6105?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=pcdeqemblzvkxny9s55lmya4
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] Selecting best audio stream for part ID 11658 (autoselect: 1 language: en)
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] Audio Stream: 24499, Subtitle Stream: 103722
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] Found session GUID of p8zpsrw905p2yy1aouwi5vvd in session start.
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] Cleaning directory for session p8zpsrw905p2yy1aouwi5vvd ()
Oct 26, 2021 05:41:53.796 [0x7f3fb37d4b38] DEBUG - [Transcode] Starting a transcode session p8zpsrw905p2yy1aouwi5vvd at offset -1.0 (state=3)
Oct 26, 2021 05:41:53.797 [0x7f3fb37d4b38] DEBUG - [Transcode] TPU: hardware transcoding: using hardware decode accelerator nvdec
Oct 26, 2021 05:41:53.797 [0x7f3fb37d4b38] DEBUG - [Transcode] TPU: hardware transcoding: zero-copy support present
Oct 26, 2021 05:41:53.797 [0x7f3fb37d4b38] DEBUG - [Transcode] TPU: hardware transcoding: using zero-copy transcoding
  1. Nvidia codecs load
  2. Transcoder invoked to play “How to Make It in America” S01E01.
  3. Note it is using the Nvidia.
  4. PMS starts sending the stream.
  5. Next I see is the start of another playback (Didn’t it start in your browser???)
Do you have another browser or playback device ?
Okay, I just started Plex in Google Chrome and this is the message when I try to access media setup on my server:
I receive the same error message using Vivaldi.
I just looked at Plex.tv.
It has not had any contact with your server in 5 hours.
Back to basics networking –
  1. The host adapter in use is enp4s0 (192.168.50.53)
  2. You are accessing it from the same 192.168.50.x subnet ?
  3. When you SSH into the host, can it ping www.google.com ?
ping www.google.com
PING www.google.com (142.251.33.4) 56(84) bytes of data.
64 bytes from dfw25s44-in-f4.1e100.net (142.251.33.4): icmp_seq=1 ttl=117 time=7.62 ms
64 bytes from dfw25s44-in-f4.1e100.net (142.251.33.4): icmp_seq=2 ttl=117 time=7.08 ms
64 bytes from dfw25s44-in-f4.1e100.net (142.251.33.4): icmp_seq=3 ttl=117 time=5.68 ms
64 bytes from dfw25s44-in-f4.1e100.net (142.251.33.4): icmp_seq=4 ttl=117 time=6.29 ms
^C
www.google.com ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 5.678/6.667/7.619/0.741 ms
Yes, I’m on the same subnet and you can see that I’m able to ping www.google.com.
hostname -I
192.168.50.53 172.17.0.1 10.32.145.35
I just tried to use my Plex link on my LG Smart TV and it says it cannot connect to PMS.
I can see my media files via localhost: http://localhost:32400/web/index.html#!/media/6747a8ad1e1f6a8637512459ca79a26ed3e97939/com.plexapp.plugins.library?source=2
But they only play randomly in my browser. When I go directly to any on the media with my file browser it all plays correctly.
LG? Is your TV one of the models impacted here?
The LG TV was manufactured January, 2019 so it isn’t that old. Also, Plex no longer works with either of my Roku devices which are not that old.
So here’s my situation: Plex doesn’t work on my computer, TV or Roku devices. Like I said in my initial post, Plex doesn’t seem to be a viable application. I have tried for years to make this work but even when I do get it working, it eventually crashes for no apparent reason.
So unless you can tell me how to fix this error message: ‘app.plex.tv is unable to connect to “linux-box” securely’, I see no reason to continue with it.
I wish you well.
Your SSL certificates are messed up. Make sure ‘Secure connections’ is set to “Required” under ‘Settings - Network’ in the web app and then if it is still not connecting remove the server from ‘Authorized Devices’ in the web app and then sign the server back into your account.
If Secure connections is not set to required then app.plex.tv WILL NOT WORK. You will have to log into the web app locally using the IP address of your server to change this setting. Once you do the above and get app.plex.tv working THEN come back here and reply to me.
