Can't start my Plex package on my synology
Hi everybody,
Since a couple of days, I can’t start my plex package anymore on my Synology.
I contacted the synology support and after some checks, they told me that this is not a problem on the synology but in the plex package.
Actual configuraiton :
Synology : DSM 6.1.5-15254
Plex : 1.10.0.4523-648bc61d4
What did I already do ? Different tests :
  • uninstall the plex package from the package synology center + install it manually with the last plex version
  • tried to reinstall from the synology package center
  • checked the hard drives
  • checked the memory
  • updated synology to the last version
After all different tests, I still have this error :
2018-02-22T18:19:21+01:00 NAS1 [214012.545625] init: pkgctl-Plex Media Server pre-start process (17795) terminated with status 1
2018-02-22T18:19:21+01:00 NAS1 synoscgi_SYNO.Core.Package.Control_1_start[17648]: servicecfg_internal_lib.c:187 Failed to start job [pkgctl-Plex Media Server][0xD900 manager.cpp:204]
2018-02-22T18:19:22+01:00 NAS1 synoscgi_SYNO.Core.Package.Control_1_start[17648]: pkgstartstop.cpp:377 Failed to start pkgctl-Plex Media Server (err=-1) [0xD900 manager.cpp:204]
Starting Plex …
/var/packages/Plex Media Server/target/Plex Media Server: /lib32/libstdc++.so.6: no version information available (required by /var/packages/Plex Media Server/target/libgnsdk_dsp.so.3.07.7)
/var/packages/Plex Media Server/target/Plex Media Server: /lib32/libstdc++.so.6: no version information available (required by /var/packages/Plex Media Server/target/libgnsdk_fp.so.3.07.7)
2018/02/22 18:19:21 start Plex Media Server 1.10.0.4523-648bc61d4 End start-stop-status start ret=[1]
2018/02/22 18:19:21 (system) trigger Plex Media Server 1.10.0.4523-648bc61d4 Begin start-stop-status stop
Stopping Plex …
2018/02/22 18:19:21 (system) trigger Plex Media Server 1.10.0.4523-648bc61d4 End start-stop-status stop ret=[0]
2018/02/22 18:19:21 (system) trigger Plex Media Server 1.10.0.4523-648bc61d4 Begin unload apparmor
2018/02/22 18:19:21 (system) trigger Plex Media Server 1.10.0.4523-648bc61d4 End unload apparmor ret=[0]
2018/02/22 18:19:22 stop Plex Media Server: begin to stop version 1.10.0.4523-648bc61d4
2018/02/22 18:19:22 stop Plex Media Server: stop version 1.10.0.4523-648bc61d4 successfully, result 0
2018/02/22 18:19:22 start Plex Media Server: start version 1.10.0.4523-648bc61d4 failed, result 272
Does anyone understand the problem ?
Thanks in advance for your help,
Dear trumpy81,
Thanks a lot for your fast answer.
Saddly, everything worked until the last step. As soon as I rennamed the old folder, same problem.
Do you have another idea ?
If not, I have no problem with configuring all again (exept the libraries). Do you know how I could copy them?
Thanks again in advance
I saddly had to re-install it completly. -> Nice configuration weekend.
