I can see my Sonos speaker in Plexamp, but when I click on any of them (I have 3), the thing spins for a bit and then goes back to my iPhone again.
Any ideas?!
Any ideas?!
I have a similar issue.
Plexamp sees my Sonos in the cast popup and will connect but audio doesn’t go to the Sonos.
It does pause and play whatever is already playing though.
I’m on android and also have 3 unit Sonos setup.
it’s known that TIDAL content doesn’t work on the Sonos devices (internal bug filed), possible that’s what you’re seeing?
otherwise, please share a plexamp log after you’re unable to connect.
Yes this would be Tidal! Ok I’ll sit tight and wait on that bug to be fixed!
