Plexamp -> Sonos streaming borked for the 2nd Tuesday in a row
Last Tuesday, and now again today, the connection between Sonos and Plexamp is broken. When displaying the “cast” options, you can see the connection to your Sonos Speakers “flapping” as it continually loses it’s connection from Plex to Sonos. It self-resolved last week after about an hour.
Troubleshooting done so far:
Re-Auth dance (Both on the Sonos side and Plex side)
Plex application reboot
Full server reboot
Playing plex directly through Sonos app (works, but of course all advanced Plexamp features are out of the window and you can only play pre-existing playlists. Sub-optimal.)
Restarting various Plexamp applications (Android, PC)
Router/Network restart
Additional symptoms:
Songs will play for 2-5 seconds successfully, but then fail consistently after that
Plexamp app becomes unusable until you manage to stop playback on plexamp as it “flaps” continually trying to play a song and failing, resetting back to a paused state, retry the play, etc etc.
When you open the cast menu, it’s clear that the connection between Plex and Sonos is flapping as each Sonos speaker shows up successfully, but will continually switch between showing the last played song and just “Sonos”. Over and over and over.
I am happy to provide logs for troubleshooting, but the reality is that this likely results from a networking issue between Plex and Sonos either due to a recent deployment or an existing issue. Please advise.
As a side note: It’s extremely frustrating to have to take time out of my day on a regular basis to troubleshoot issues that are outside of my control and that do not end up on your Statuspage as an acknowledge outage. The Plexamp → Sonos connection completely opened the door for me to switch to Plexamp and get rid of Spotify, but it doesn’t really feel like this is a supported feature by the Plex team and I’ve seen multiple other posts throughout the years that articulate the same thing. Bugs that have been around forever, like having to hit play 2-4x every time you want to start a new queue are still around and have been for years. Having to magically re-authorize Sonos and Plex talking to each other, on both sides, without ever getting a notification that anything has expired or an expectation of when this auth flow expires. Not to mention the amount of digging one has to do to discover for themselves how to find the pages to re-auth. And that is 80% of all the posts I see on these forums as well as other sources like reddit when people have issues streaming Plexamp → Sonos. It actively drives away users who are interested in your solution and product. Reliability isn’t as sexy as coding new features, but new features that don’t work aren’t sexy from a consumer viewpoint.
Same issue here, I restarted everything, no difference.
+1 for me on this issue, exactly as described, which started about 1 - 2 weeks ago. Same behaviours on Windows, Android and iOS apps at version 4.10.1.
same here, has been an issue for quite some time.
*I will rephrase, it was pausing a number of times and then found its way, but of late (like today- i don’t use it everyday) it is not a complete stopper as you put it. So i don’t believe this muddies the water.
I doubt we’re talking about the same thing. Having to deal with the queue pausing 1-2 times but working fine afterward is annoying but not a complete show stopper like what is happening now. If you’ve been experiencing this issue for “quite some time” the problem is likely on your end or over-exaggerating an existing bug that’s been around forever and is merely annoying. This specific behaviour started last week and re-surfaced Tuesday of this week.
Don’t muddy the waters, it makes it harder to investigate on their end.
