Server Version#: 1.22.2.4276-7000
Player Version#:na
Not always, but often I get the error message attached when trying to upgrade the Plex server via the Package Center in Synology)
My Synology has DSM 7.x btw
Does anyone has a tip?
Player Version#:na
That’s something in DSM itself . I’ve been seeing it as well.
I’ve asked the question at a Synology forum. If I get a valid answer, I’ll post it here.
No response from Syno forum but I solved it this way:
ssh user@NAS-IP
navigate to the folder you copied the .spk file
sudo synopkg install name_of_the_plex_file.spk
[password]
rm *.spk
Hi, another method I found is to not use Edge browser. I don’t have that problem when I use Chrome.
