Cast Metadata Incorrect
For the most part, the cast metadata for movies comes down without issue, but there are at least a couple of instances (that I’ve found so far) where cast metadata is mixed up. One example is the 1996 movie, “Fargo”. For “Fargo”, the cast is simply listed as “Fargo 1996”. I’ve tried manipulating and changing Movie Agents (“Plex Movie”, “The Movie Database”, “IMDb”), followed by a metadata refresh, but I can’t get the cast metadata to update.
Anyone have any thoughts on what I’m doing wrong or how to fix this?
Please post the Plex XML info of this movie.
The cast info is correctly listed at TheMovieDatabase
and has been that way since quite a while already.
So either you are using a different metadata provider for cast info or these get overridden by embedded cast info from mp4 files.
Try this:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Afterwards, clear the local meta data cache of all agents
https://support.plex.tv/hc/en-us/articles/202967376-Clearing-Plugin-Channel-Agent-HTTP-Caches
Then ‘Refresh Metadata’ in this particular movie.
Thanks for the response!
I couldn’t get the XML to display in Safari (Chrome worked after the fact), but it’s a moot point because following the instructions you provided, Fargo now has cast metadata associated with it! I ran through some of the other movies that had the same problem, and they’re all better now too.
Thanks for you help. :slight_smile:
When I try to Filter by Actor, many of the listings display actors concatenated by |, /, or ;. Some of the movies do not show all of the Cast members because the names are concatenated together. I looked at the file Properties, but they are empty. How is this happening. Thanks
Find a movie where such a concatenated actor appears.
Please post the Plex XML info of the movie.
Mixup of Actors:
Will Smith: https://www.themoviedb.org/person/2888-will-smith?language=de-DE
Bad Boys, I Robot, I am Legend, …
Will Smith: https://www.themoviedb.org/person/234120-will-smith?language=de-DE
Paddington
They seem to be mixed up, as Paddington shows the wrong Will (Bad Boys) and when updating Metadata and the correct Will is shown, then Bad Boys, I Robot, … show the incorrect Will.
XML Paddington (showing the correct Will Smith):
https://pastebin.com/brL1cs3J
XML Bad Boys (showing the wrong Will Smith):
https://pastebin.com/hNpvkABx
Appends to all other “Will Smith” movies then.
When i do a metadata update for Bad Boys for example, the Will Smith of Paddingtion is changed also.
Anyone?
