Cast music to dietpi raspberryPi streamer
I’ve been casting my lossless music to a Chromecast audio. I’m going to “upgrade” away from that over to a raspberryPi based streamer. The streamer does have spotifyd (Spotify Connect) but there doesn’t seem to be any similar software for Plex: to stream Plex audio to a raspberrypi based streamer. Any ideas? thanks
ha! I think this is it
@odinb1 awesome script up there. I’m curious: does running the bash script wipe the SD card and the copy of DietPi that’s already on there? If so, will other streaming end points stop working? (spotifyd)
Hi!
No, it does not! It does however modify the existing system, so depending on what you have, it might or might not work!
See also this comment on the wiki:
"Re-running the script
The script can be re-run to fix configuration/setup errors, just say no/bypass the sections you do not want to re-run!
For hostname-change, please make sure to reboot in-between, or you might face issues."
Good luck!
