so is there a way of using the unlimited cloud as a "drive" on plex and stream from it?
Maybe, I was able to do this with Bitcasa and think it should be possible with ACD also, but I'd think we may need to wait until NetDrive gets a wee bit more stable. I'm still seeing a bit to many IO timeouts (recovers fine).
kinda like a chromecast, you control the stream you point it to, but once its connected to the stream its direct from the source aka cloud?
would mean people with naff upload speed could theoretically [once they'd got it all up there] be able to serve loads of people from the cloud uplink.
Nope, It would just become a drive letter on your system like any internal, network or USB drive. Everything would still need to go through your Plex Server. However, if down the road Plex adds ACD as a true cloud provider then this could become possible.
ahhh, but the PMS is what does the transcoding where required.
its an interesting idea.
hell, for the cost of the cloud space, I'd send an i7 NUC to them and tell them to plug it in! :D
You could get a VM machine and setup Netdrive on it and run everything in the cloud that way I suppose.
let me know how transparent raid goes. i like snapraid but the manual snapshots are its only real weakness as far as data protection
Yea, not a fan of snapraid either. FlexRaid also has a product similar to that called Raid-F.
I'm still shuffling data around my network. I'm doing multiple things at once:
1 - Moving data off 2 new SSDs so I can use one for operating system and 1TB SSD for Plex MetaData.
2 - Moving stuff from one of the 6TB drives so I can remove the file system so it can become a parity drive.
3 - Already filled first data drive and working on a 2nd data drive at present (pre-populating them)
4 - Continuing to upload data to Amazon Cloud Disk (ACD) and have 13.6TB uploaded so far.
I'll be away for 2 days starting in the morning (picking my daughter up from university) so I'm trying to get the hardware setup the best I can so I can remote in and keep things moving along properly.
Once I get 2 & 3 done I'll be trying a 3 disk test just to get the hang of it. I'll definitely keep notes of any "gotchas" or "goodies" I come across and will post them here.
Carlo
