CEC Remote Buttons
Hi all.  I've got RasPlex set up to use the TV remote buttons via CEC/HDMI (Vizio TV remote mapped to a Logitech Harmony).  I can't get Plex's "Info" button to work though, the Info button that brings up the progress bar at the bottom with the playback control and the audio/video options on the right.  Has anyone had any luck mapping this button to CEC controls?
For that matter, using Page Up/Page Down, Fast Forward, and Rewind don't seem to work properly using CEC either.  I can skip forward and back 30s or 5m though.  Is this how it's supposed to work in RasPlex?  Thanks!
First: There are some known issues regarding non-functional remote buttons. Just search the forum.
The CEC implementation of some manufacturers seems to use some custom stuff which won’t fully work with RasPlex.
It seems LG is not well supported. Sony and Samsung TVs seem to be more compatible.
(You may take a look at the PlexHT debug log to find out if a button press was recognized by PlexHT or not…)
The CEC implementation of some manufacturers seems to use some custom stuff which won't fully work with RasPlex.
(You may take a look at the PlexHT debug log to find out if a button press was recognized by PlexHT or not...)
Thanks! I'll take a look.
I'm using a Samsung CEC remote with Rasplex.  Is there a list somewhere of what functions are assigned to different buttons?  For example:  I stumbled into finding that the yellow key automatically takes me to my music channel page.  I'm curious if there are other functions/buttons other than the typical arrows and playback buttons.
