CEC remote disconnects?
I seem to be having some problems with CEC where during playback or sometimes if left idle for long enough the CEC commands no longer seem to be recognised - I press a button and get no response and if I press the "select" button the TV responds as if the rPi is no longer a connected CEC device.
I have been using raspbmc successfully with CEC for many months with none of these issues so I am assuming there is a bug somewhere perhaps causing libcec to crash and not be restarted? Has anyone had similar issues?
Hi, the cause could be that you have another HDMI device connected to your TV that makes your remote not responding. This was my case, I just disconnect mi cable decoder and my remote works again. It's a bit of a pain to do this so I use my plex app for Android  :)
I have nothing else plugged in via hdmi and is working just fine with raspbmc so I'm pretty sure its a softare issue
