If you’ve installed ssl then just open cmd and run as administrator then copy and paste the command txt into that but change .bat to .cer, then the 3files will appear on your computer. Install the certificate and add it to profile on Apple TV and move the pem file to the certificates folder in plex connect
Isn't the change to .cer only required for windows 8, I have used the .der file on win 7 successfully and only when I upgrade to windows 8 did require to use a .cer certificate
If you are trying to put it on the ATV via the network option (Which he said he is doing) then Plexconnect WIKI says cer. If you use the iPhone Config Util then the der works.
Thanks for the clarification f00b4r, however if he has used the old Der instructions then he should be adding the profile to ye ATV via the network option using
thanks for alll!!!!! its working now ... but i can navigate in plex but when i try a channel (ex. pbs) i can chose something s01e12, clic enter and after ino responce from plex media server. i will search what to do but if you have some idea for that !!1
by the way
i prefer the installation with note pad and shift left clic
