Generate certificate
Im trying to follow this guide to generate the win certificate.
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Windows-Certificates
at this stem im getting:
google gives me nothing
"C:\>C:\OpenSSL-Win32\bin\openssl.exe x509 -in C: railers.pem -outform der -out
C: railers.cer
unable to load certificate
2768:error:0906D06C:PEM routines:PEM_read_bio:no start line:.\crypto\pem\pem_lib
.c:703:Expecting: TRUSTED CERTIFICATE"
any idea?
my C. root has now gotten the files "trailers.pem" and "privkey.pem"
>>C:\OpenSSL-Win32\bin\openssl.exe x509 -in C: railers.pem -outform der -out C: railers.cer
This is ONE line, is it?
Not sure about Win... did you/do you have to run it with admin privileges?
yes
yes cmd promt is started with run as administrator.
I just looked at the wiki page, and I'm pretty there's a typo in that command. The file should be trailers.der rather than trailers.cer (the command has 'der' in it).
That's the only difference I can see between the command listed on the wiki and the command not the blog that the wiki refers to (below) that worked the last time I installed PlexConnect.
C:\OpenSSL-Win32\bin\openssl.exe x509 -in C:	railers.pem -outform der -out C:	railers.der
Cer is used to be universal for the network add. And cer worked fine for me
