@OttoKerner Can you please fix mine as well? Iāve been struggling to figure out whatās causing this, I shutdown my server overnight hoping this morning would resolve on start but it hasnāt. The cert expired yesterday and it wonāt renew. Below log every 20 minutes before I shut it down.
Issued by: R13
Expired: Friday, May 15, 2026 at 4:47:41 PM Mountain Daylight Time
May 16, 2026 13:09:36.419 [127102177209144] ERROR - [CERT] CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[mod edit: Start it back up and let it sit for a few hours.]
EDIT: Working now, new 3 month LE cert, thank you!!!
My serverās certificate is also expired and the renewer is stuck in a 429 loop. Iāve masked details below but can DM the full machine identifier and account email on request.
Server details:
machineIdentifier: 029c0bā¦e0fc
Plex version: 1.43.1.10611-1e34174b1 (Linux)
Cert expired: ~2026-05-17
Plexās renewer detects the expired cert and requests a new one, but plex.tv returns 429 on CSR upload. Server remains stuck at āMapped - Not Published (Not Reachable)ā. The web UI works via the web app (app.plex.tv), but native apps (ios) cannot connect because of the expired cert. Restarting Plex does not clear the rate limit.
Log snippet:
May 17, 2026 02:34:24.375 DEBUG - CERT: Certificate expires soon, fetching a new one.
May 17, 2026 02:34:24.376 DEBUG - [HCl#12] HTTP requesting GET https://plex.tv/api/v2/devices/[ID]/certificate/subject
May 17, 2026 02:34:24.421 DEBUG - HTTP/1.1 200 response from GET .../certificate/subject
May 17, 2026 02:34:24.537 DEBUG - [HCl#13] HTTP requesting PUT https://plex.tv/api/v2/devices/[ID]/certificate/csr?reason=expiring&invalidIn=-14962
May 17, 2026 02:34:24.557 DEBUG - HTTP/1.1 429 response from PUT .../certificate/csr
May 17, 2026 02:34:24.557 ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429
Thank you
[mod edit: you can stop and restart your server now.]
[mod edit: Youāve had 6 new certs delivered to you in short succession. Before, you also requested a new certificate every ~10 days. So check if you are doing something wrong, like completely emptying out the cache folder. Now you are rate-limited. Shut down your server for at least 12 hours, then start it back up. Donāt clear out the whole /Cache folder within your plex data folder when experimenting.]
Seems to me that Plex has some sort of serious issue going on with their end. They should at a minimum be posting an announcement about WTF is going on and what theyāre doing to remedy it!
Iām having the same issue. Could a moderator please help. May 17, 2026 01:06:09.747 [11436] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[mod edit: Your certificate is valid and has been successfully renewed a few hours ago.]
I am also having the same problem. I canāt even access the server through the web interface now. It went from fine, to visible only on the local network to not visible at all.
