Change ratings to Australian
Hey guys would just like to know if its possible to change the ratings in plexconnect to Austrlaian. Right now it shows the ratings but in US even though my library has them in Australian ratings.
Thanks alot.
Mine are also Australian and they show up as Australian in plexconnect. Not the pretty logo like in other plex apps but just the text equivalent with a square box around it. Maybe they aren't in properly on your server? Photo attached.
Is your ATV’s region set correctly to Australia?
Is your ATV's region set correctly to Australia?
Only need to set your plex server to display the Australian ratings. My ATV is set signed into US iTunes store, only Australian setting I have is the timezone. If the problem is server side, I have noticed that where plex pulls the ratings from ( themoviedb.org) is very lacking for Aus ratings. I have been adding to their site for movies I have but then end up putting the ratings into plex myself as the website takes close to a month to update itself before plex can see the ratings I've updated. If it cannot get an Aus rating it pulls the US one. Compare some titles you have to the TMDb and you might find they are all titles that have no Aus rating on there.
