Channel 35.1 in Orlando incorrectly shows as America Teve' rather than Fox
Channel 35.1 is otherwise working. It just shows programming information for the wrong channel. If you tune to it, you see Fox as expected.
I am using an HDHomeRun and this was working correctly on an earlier server (I upgraded the drive and reinstalled everything).
I’ve tried re-scanning the channels several times with no changes.
I’ve tried refreshing the guide with no changes.
Not sure what to try next. Is there a way to edit the channels?
This post outlines the process for reporting issues with EPG data:
Thanks. I am going to delete the DVR and reinstall it during a time when nothing important is on it. If the problem does not go away then, I will report the incorrect channel.
Is there a functional difference between forcing a rescan and deleting the DVR?
