Channel scan ignores ATSC 1.0 stations - Only shows ATSC 3.0 stations
Server Version#: 1.30.0.6486
Player Version#: unsure
Tuner Make/Model: HDHOMERUN Connect Flex 4K
Guide/Lineup name: Local Broadcast Listings (Houston, TX)
Using XMLTV?:
Channel number/Name:
I’m dealing with multiple record issues and in troubleshooting I decided to delete and rebuild the DVR function. All goes well until the channel scan and none of the major Houston stations broadcasting in ATSC 1.0 show up in the scanned channel list. I can only see their ATSC 3.0 equivalents. For example 2.1 does not show up, but 102.1 does. How can I force the scan to also show the ATSC 1.0 stations? I seem to remember a workaround, but I’m not finding it on the support pages.
Do they appear on http://hdhomerun.local if you scan there?
Thanks so much for answering. I believe I have figured this out. I went in to the HDHomeRun App and unchecked the NextGen channels and rescanned. This picked up the ATSC 1 equivalents for the HD app channel lineup. Going back into the Plex app, the ATSC 1 channels now are present. Plex is downloading the guide data now.
