Channel showing in Live TV & DVR, but not showing in guide
Server Version#: 1.24.5.5173
Tuner Make/Model: HDHomerun Connect Duo
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
I have a relatively new channel in the area. I have been through new channels before. You have to wait until Gracenote has it, then it will show up available to assign in your Live TV & DVR settings. You can then assign it, the guide refreshes and there you go, new channel in the guide.
This is not the case for this channel. It has appeared, available to assign in the Live TV & DVR settings:
As you can see it says 133 channels. It is not in the guide and the guide says 132 channels. I have checked Gracenote’s site and they have guide data for the channel (so it’s not “unknown”). Doesn’t seem to matter what client I use (I have tried Plex Web and iOS app). Any ideas?
It has randomly appeared in the guide overnight, so I guess issue solved…
