Can't match channels to guide info
Server Version#: 4.66.1
Tuner Make/Model: HDHomerun FLEX 4K
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: 25.1 FOX
Hello! I’m trying the Live TV/DVR functionality for the first time. Unfortunately not all of my channels show up. I checked the settings and it seems to be because there is no guide info. Some channels I never heard of but I can’t match FOX. I tried matching it to the wrong data so it could at least access it but it doesn’t save. Is there a way to find additional guide data so I can see all my channels?
Answered on Reddit. Delete the DVR and create a new one using a zip code that’s closer to the towers. Not an elegant solution but it worked for now. Hopefully a future update will allow you to pick from towers further away.
