Hello,
It’s a nightmare to use DVR when your postal code is not linked.
First, the list of channels starts with stupid numbers. How can I search a name ?
Secondly, the short name aren’t clear for most of channels.
Third, why isn’t it possible to map channels manually, like I can do in EyeTV 3.
I have 250 channels but with your setup I can only watch 10.
This is ridiculous. As well as the program guide, I’m not fan at all. Most of programs does not even appear. Because you have only some categories.
Please, add codes 1000-1018 for Switzerland as we want to setup this feature.
OK when you are Plex Pass Lifetime you don’t bring money anymore, so they don’t care nor even reply to support request anymore.
Since they work on DVR they add bug at each updates on things which were working fine before, it’s a bit sad and it’s really time to change and find another team.
Have you posted your channel issue in the thread setup for EPG Data for countries. Not sure if it really applies to you since you stated you do have some data but sounds like you are missing data for channels.
You can also file it using the EPG Data Google Form that Plex put out:
