A PMS with no transcodes can be run on a Raspberry Pi, so I don’t understand your question.
The Ryzen is the much better CPU obviously, but the G will be enough for what you ask for.
thank for your response. just wanted this clarified. so there is no real benefit of using a better cpu as no transcoding happens in hardware … and as you rightly said even a raspberry pi would suffice…so from a power consumption/efficiency perspective , trust im better off using the Intel g4560 processor of the two options I have iguess…
Well it depends as usual. If you have to transcode a TrueHD 7.1 it can be more demanding than you think. If this happens for several streams in parallel, more CPU is always better
But your Pentium G might be enough for it, can’t tell.
in that case is it a hardware transcode where the CPU is actually used or some kind of software transcode… this is my confusion… what does Plex hardware transcode requiring Plex pass mean in this case?
Software means it is run by the CPU, can be confusing. Hardware means video transcodes that are done by the integrated graphics unit of the Intel CPUs or via a dedicated graphics card.
The G4560 even has this integrated graphics chip so if you want to buy a Plex pass in the future you would be able to benefit from hardware transcoding (for video).
I guess the Ryzen also has an integrated graphics unit, but it can’t be used by Plex (yet). Nobody knows if and when that changes. Speaking of today, the G4560 is the better option if you want to use hw transcoding.
