Beta 6.15.0.3852, Chromecast Audio playlists not working, plays only the first track.
Reproduced on 3 different devices.
Albums play okay.
Albums play okay.
Tried but cannot reproduce. Can you explain a little more deeply what is happening?
This is what I did:
Also, if you can check:
Hi antoniolg
Thank you for your reply.
Based on your questions I have completed the following testing:
This was tested with ChromeCast Audio via the Android App, iOS 16bit app, Windows 10 Chrome browser, with the same results.
The old playlists play fine locally via Android App, iOS 16bit app, Windows 10 Chrome browser, seems to be a casting issue.
The above was all tested on Chromecast Audio.
I then tested casting to Chromecast TV, old playlists work fine on the Android App, iOS 16bit app and Windows 10 Chrome browser.
Therefore, looks to be an issue with the Chromecast Audio casting code.
Please let me know if you have any further questions or whether I can provide any logs etc?
Many thanks,
Steve
Thanks. There’s some chromecast work in progress, which will probably fix this. Will let you know if we need more logs.
