Server Version#: 1.21.1.3830 (NAS Synology)
Player Version#: 8.11.0.22186 (Android)
From what i’ve seen, it’s a common issue. On my Phone, when i’m casting to my Chromecast Ultra, i can’t use my phone to control the volume. The only way i can is through the Plex app, only when it’s open.
With other apps, i can control volume of my chromecast from anywhere, even when the phone is locked with screen off. The Chromecast volume is attached to the Android volume system panel.
I’ve tried a lot of chromecast.xml solution but it seems like it won’t work.
Have you found a solution ?
Thanks !
