Claim Server
Could you add me or can you give me your tag to add you? Much easier to discuss then plex forum.
Oh… you mean Plex forums… Sorry.
I use Discord for a game I play. :slight_smile:
Discourse is what Plex uses for the forums.
It’s actually a lot easier to find me here , in a thread, with @chuckpa No tag needed
I’m notified of every Linux-based forum post and threads where I’m called by name.
I manage to redo everything… but my unraid server does not want to take the new ip… I lose access to it.
I am looking at Plex.tv
I see the old server names you had.
You had a few that worked.
The most important things to remember when claiming –
  • USE IP LAN IP ADDRESS ONLY
  • You must be on the same subnet as it
I need to run. @FordGuy61 will help from here. Sorry
Yes I had, then they didn`t wanted to work anymore.
@xSniper89 Checking in. Were you able to get things re-addressed? If so, can you claim the server?
Yes it seems like that was the issue. The Local IP. You guys should put a warning for that just in case. World is full of newbies like me :slight_smile:
Thank you for the support. Much appreciated.
