I have a PMS installation with a large config directory (60GB+) that I have copied from machine to machine over the years of running Plex. It has a huge amount of effort involved into the metadata, so I don’t want to lose it.
Recently I have started to experience occasional PMS hangs for no apparently reason. I have tweaked settings and looked through logs with no real luck to pinning down the cause. I posted logs on forums with no luck there either. No one else seems to be having these types of hangs, so I figure it is something unique to my setup.
I am migrating from Plex running under Debian to the Docker version of Plex, all on a high end dedicated server. My hope is by moving to Docker these hangs will go away, but I have a fear they’ll continue because my installation was pretty standard, and of course I am still using that same configuration directory.
I noticed I had some very old plugin versions (things like Google Music, Unsupported App Store, Pandora, etc) in my plugin directory that I never use. In my desire to clean everything up, I removed all these plugins via the UI. However, my plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins directory still shows this:
DevTools.bundle/ Services.bundle/ SiteConfigurations.bundle/ WebManager.bundle/ master.zip*
The first 4 are directories, the last one is a file. Should I delete these? Leave them as-is? Replace them? They have dates from 2014 (except for Services.bundle).
Any other suggestions on “cleaning up” my installation? Other than blowing away all the metadata and starting from scratch, of course!
