Client Transcoding And I Don't Know Why
So I’ve allowed my friend access to my server to stream remotely, but we are having issues with transcoding when it should be direct playing.
In the pic below:
  • (Left: QN65Q70RAFXZA) Him playing on his TV with HDR10+ and HDR10 support
  • (Right: Galaxy Tablet S7 FE) Him playing on his tablet, direct playing
The file he’s playing is 4K with DV, HDR10+, and fallback HDR10. He should be able to natively play 4K HDR10+ or at least HDR10 with his TV. Why isn’t it falling back and instead transcoding to 1080p?
Remote streaming is set to original and 50Mbps max, which this is under. Video quality is set to Maximum in Plex Web.
Here are the logs…
Plex Media Server Logs_2025-05-03_13-12-15.zip (926.3 KB)
can’t see what’s happening because you’ve turned off DEBUG logging.
however, what I can see is pretty bad.
  1. DNS error
  2. GPU error
May 03, 2025 12:43:22.220 [140558094490424] INFO - [Req#12ea4/Transcode] Preparing driver icr for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:43:22.233 [140558094490424] INFO - [Req#12ea4/Transcode] Preparing driver ivd for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:43:25.785 [140558014745400] ERROR - [Req#12eb4/Transcode/e12gci6b53cf1z1l71gqfnu5/bb7672e2-16a3-4720-ac30-f86210a679eb] [AVHWDeviceContext @ 0x7fa26ea709c0] No matching devices found.
May 03, 2025 12:44:42.135 [140558012635960] WARN - [Req#13361/Transcode] Streaming Resource: Bandwidth exceeded: 24373 kbps > 15627 kbps
May 03, 2025 12:44:42.262 [140558014745400] INFO - [Req#13365/Transcode] Preparing driver icr for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:44:42.264 [140558014745400] INFO - [Req#13365/Transcode] Preparing driver ivd for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:44:42.505 [140557995572024] ERROR - [Req#13375/Transcode/e12gci6b53cf1z1l71gqfnu5/14fd0d93-5ac2-4315-8a72-97c8c23a05e4] [AVHWDeviceContext @ 0x7f9363e17c40] No matching devices found.
May 03, 2025 12:44:49.867 [140557995572024] INFO - [Req#13410/Transcode/e12gci6b53cf1z1l71gqfnu5] Preparing driver icr for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:44:49.869 [140557995572024] INFO - [Req#13410/Transcode/e12gci6b53cf1z1l71gqfnu5] Preparing driver ivd for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:44:50.131 [140558014745400] ERROR - [Req#13439/Transcode/e12gci6b53cf1z1l71gqfnu5/5abf0d7d-c06b-4efa-8dd3-3792321d1f4f] [AVHWDeviceContext @ 0x7f97f8983480] No matching devices found.
May 03, 2025 12:46:06.597 [140558153157432] WARN - [HttpClient/HCl#1fd] HTTP error requesting GET https://plex.tv/api/v2/server/users/10542357/view_state_sync (6, Couldn't resolve host name) (Could not resolve host: plex.tv)
May 03, 2025 12:46:06.597 [140558090271544] ERROR - [Req#13773/ViewStateSync] MyPlex: Error -6 requesting JSON from: https://plex.tv/api/v2/server/users/10542357/view_state_sync
May 03, 2025 12:48:02.351 [140557995572024] WARN - [Req#13eab/Transcode] Got a request to stop a transcode session without a valid session GUID.
May 03, 2025 12:49:46.633 [140558014745400] ERROR - [Req#14028] Unknown metadata type: folder
May 03, 2025 12:49:47.048 [140557995572024] ERROR - [Req#14073] Unknown metadata type: folder
May 03, 2025 12:50:46.699 [140558094490424] WARN - [Req#14167/Transcode] Streaming Resource: Bandwidth exceeded: 24373 kbps > 15627 kbps
May 03, 2025 12:50:46.870 [140557995572024] INFO - [Req#1416a/Transcode] Preparing driver icr for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:50:46.879 [140557995572024] INFO - [Req#1416a/Transcode] Preparing driver ivd for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:50:47.611 [140558094490424] ERROR - [Req#1417b/Transcode/ml42a7xv212jeq069nekx12e/c6b3b538-6a30-4a83-8ab0-28a989d004ad] [AVHWDeviceContext @ 0x7f2e85f6bc40] No matching devices found.
May 03, 2025 12:50:50.666 [140558014745400] INFO - [Req#141cb/Transcode/ml42a7xv212jeq069nekx12e] Preparing driver icr for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:50:50.667 [140558014745400] INFO - [Req#141cb/Transcode/ml42a7xv212jeq069nekx12e] Preparing driver ivd for GPU Intel GeminiLake [UHD Graphics 600]
May 03, 2025 12:50:50.916 [140558012635960] ERROR - [Req#141f2/Transcode/ml42a7xv212jeq069nekx12e/090061cd-6c06-471b-ba5e-132fdcb0de25] [AVHWDeviceContext @ 0x7f7e2c792480] No matching devices found.
May 03, 2025 12:51:48.505 [140558094490424] WARN - [Req#14575/Transcode] Got a request to stop a transcode session without a valid session GUID.
Yeah he was getting a CPU error on his end, I have an iGPU. I noticed DDNS was down on my server, updated and it came in after. Something weird hit me last night that knocked my internet and remote service out for awhile. I’m in Pittsburgh, so assumed it was related to the earlier storm. I can do Debug logging and have him repeat if that’s what’s needed to diagnose?
I will need DEBUG server logs so I can watch what it’s trying to do up to the point of failure.
INFO, WARN, ERROR are ok when it’s all running normally but as soon as an issue pops up, DEBUG is needed
Plex Media Server Logs_2025-05-03_18-56-38.zip (898.0 KB)
My friend found a direct play option for live streaming, and that stopped. But logs attached. Not sure on movies streamed remotely
@smann
You’ve got a DNS error.. PMS isn’t going to work right without it.
May 02, 2025 20:21:00.556 [140558153157432] WARN - [HttpClient/HCl#5a] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:02.523 [140558195063608] WARN - [EventSourceClient/pubsub/172.104.216.125:443/PubsubServerManager/getNextWorkingHost/ewr/process] Connection to 172.104.216.125 failed: Operation timed out.
May 02, 2025 20:21:02.523 [140558195063608] ERROR - [EventSourceClient/pubsub/172.104.216.125:443] Retrying in 120 seconds.
May 02, 2025 20:21:08.510 [140558153157432] WARN - [HttpClient/HCl#5b] HTTP error requesting GET https://plex.tv/users/02f4a78d478fda45/avatar?c=1746231517 (6, Couldn't resolve host name) (Could not resolve host: plex.tv)
May 02, 2025 20:21:10.340 [140558153157432] WARN - [HttpClient/HCl#5c] HTTP error requesting GET https://metadata-static.plex.tv/5/gracenote/5ea8ea859a4a66fb12a48f4761d004ea.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:10.344 [140558153157432] WARN - [HttpClient/HCl#5d] HTTP error requesting GET https://metadata-static.plex.tv/0/gracenote/04b5e97a3d6b7f485fd686a4ea3fb580.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:10.456 [140558153157432] WARN - [HttpClient/HCl#5e] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:20.359 [140558153157432] WARN - [HttpClient/HCl#5f] HTTP error requesting GET https://metadata-static.plex.tv/5/gracenote/5ea8ea859a4a66fb12a48f4761d004ea.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:20.366 [140558153157432] WARN - [HttpClient/HCl#60] HTTP error requesting GET https://metadata-static.plex.tv/0/gracenote/04b5e97a3d6b7f485fd686a4ea3fb580.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:20.488 [140558153157432] WARN - [HttpClient/HCl#61] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:31.027 [140558153157432] WARN - [HttpClient/HCl#62] HTTP error requesting GET https://metadata-static.plex.tv/0/gracenote/04b5e97a3d6b7f485fd686a4ea3fb580.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:31.037 [140558153157432] WARN - [HttpClient/HCl#63] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:31.067 [140558153157432] WARN - [HttpClient/HCl#64] HTTP error requesting GET https://metadata-static.plex.tv/5/gracenote/5ea8ea859a4a66fb12a48f4761d004ea.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:40.718 [140558153157432] WARN - [HttpClient/HCl#65] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:41.127 [140558153157432] WARN - [HttpClient/HCl#66] HTTP error requesting GET https://metadata-static.plex.tv/0/gracenote/04b5e97a3d6b7f485fd686a4ea3fb580.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:41.180 [140558153157432] WARN - [HttpClient/HCl#67] HTTP error requesting GET https://metadata-static.plex.tv/5/gracenote/5ea8ea859a4a66fb12a48f4761d004ea.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:50.928 [140558153157432] WARN - [HttpClient/HCl#68] HTTP error requesting GET https://metadata-static.plex.tv/c/gracenote/c46a9de0843dd5a085809d90011b3244.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:21:50.949 [140558153157432] WARN - [HttpClient/HCl#69] HTTP error requesting GET https://metadata-static.plex.tv/0/gracenote/04b5e97a3d6b7f485fd686a4ea3fb580.jpg (6, Couldn't resolve host name) (Could not resolve host: metadata-static.plex.tv)
May 02, 2025 20:22:43.429 [140558129810232] WARN - [Req#23d] MyPlex: attempted a reachability check but we're not yet online.
May 02, 2025 20:23:15.798 [140558153157432] WARN - [HttpClient/HCl#6a] HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (6, Couldn't resolve host name) (Could not resolve host: plex.tv)
May 02, 2025 20:23:15.798 [140558115044152] ERROR - [MediaProviderManager] Error parsing content.
do a nslookup plex.tv
