Cloud Sync allows you to sync content from your library to a cloud storage provider so that it is available for you to stream even if your Plex Media Server is not accessible.
You need Plex Pass to use Cloud Sync. After that you choosing Dropbox and you sync some of your files to cloud. After sync is done you can watch it from cloud even if you Plex server isn't online.
No, you can't just copy files to Dropbox, you need to sync them. Cloud sync isn't replacement for you PMS, you should still use your local drives/nas/etc to store media.
Plex keeps all files locally, not on the iPad itself but on your local network. You have to have a Plex server running. You can then sync some (all??) files to the cloud and play them from there but your files still need to be kept locally.
If you setup Plex and keep your files locally you can Airplay them from Plex to your aTV through your iPad from your local network.
I guess if you uploaded all your files from Plex to Dropbox you could turn off your server and just stream from Dropbox but you would first need to upload everything from Plex. Plex cannot access the files on Dropbox directly.
Well, rather than posting more here you should probably go to
www.google.com
and start searching for something.
You obviously understand that Plex is not for you.
(BTW, that is not "the problem". Plex does what it does very well. You don't want what Plex does. The problem is you want Plex users to tell you what to use other than Plex.)
Have a great day and good luck in your search on Google.
(And I guess you did not see this from me:
Of course you still need a PlexPass to do that and you would need to setup Plex initially.)
This is very disappointing. It would seem to me that Plex should be able to accomplish this rather easily. If it’s able to store files from Plex into Dropbox that means you have an API to communicate with Dropbox; and if you have that, then it would seem that the next step would be the ability to stream directly from a cloud provider.
I guess my point is, why don’t you all offer this service, since it’s not that far from what you’re already doing?
The reason is file compatibility. Most clients, like apple tv and ios devices, have a very limited set of codecs they can playback, so before uploading Plex transcodes the file to a widely accepted format (h264 and aac 2.0 sound I believe).
Plex Cloud, currently in beta, is what you’re asking for… But its not good enough to be actually usable at this point.
