Collections (selecting problem)
V3.77.4 (server)
I am unable to scroll down to select the proper collection when editing tags. I currently have 5 but when I try to move the slider to see the ones below it pops away leaving a box without a slider and you can’t select the collection you want.
V3.83.2 (windows client)
I have this problem when running directly on the server and when running my windows client. Exact same fault on both.
  • When there were only two collections and you could see them It was not a problem. However once the collections list was long enough it would not fit the screen that is when I discovered the slider bar was not working properly.
  • When selecting a collection from the movie menu and not editing a tag they are all listed and easy to click. This is only when editing a movie tag to add it to your collection.
Anyone?
Please some one try collections on their own system and tell me if I am crazy here.
This is a known issue with the edit modal.
It is expected to get solved when this whole thing is redesigned.
In the mean time you can only solve it with a mouse which has a scroll wheel.
Thank you.
what is the redesign? When is it expected?
I can’t tell you about future development, sorry.
