I am creating collections in order to set up smart playlists that update constantly when I add new movies to certain collections. The problem is that the collections section only shows part of one line. You can’t make the window larger, so it is very difficult to work with the collections in tags. I would love to be able to make that window larger so it can be viewed better.
I realize this is an old post, but surely there is a way to fix this?
Editing Collections from the edit Menu is a pain. It just needs a few extra lines in the window to make it bigger?!
Thanks, ported this to Stylus.
