Column titles and columns not correct in list view after about 400 movies in the list
Server Version#:1.18.0.1913 and 1.18.0.1944
Player Version#: web: 4.8.4 windows-plex: 1.3.1.916-1cb2c34d plex-media-player: 3.104.2
This error is already in plex for as long as I can remember from the moment I had a list of over 400 items.
After about 400 movies or videos in one movie list, then the list view isn’t working correctly anymore.
The selected columns are shown in the title header, but the culumns for the movies don’t change.
see picture.
for example, title content rating is showing the year and the resolution is showing the viewed collumn.
When I open a list with less items (a collection for example) then the columns and titles are working corectly.
Also a new movie list with less items in it will work correctly.
Possibly related to collections?
I have a library with 800+ movies.
Using Plex Media Player 3.104.2 on Windows 10, PMS 1.18.0.1913 on Synology DS918+.
With collections = disabled, I do not see the problem.
With collections = Hide items which are in collections, I see the problem, but strangely, only when sorted from Z -> A. Sorting A -> Z lists things correctly.
With collections = Show collections and their items, I do not see the problem.
Edit: I also see the size dependency. A library with ~350 movies does not show the problem, regardless of collections setting.
Indeed,
It has something to do with the collections. If I change Collections to “Disabled” (in Advanced in the library settings) then the problem goes away. Then the list is again normal. But if I use 1 of the other settings, then the layout is messed up again.
collection%20selection
But if I use a smaller library, then everything is working normal. with or without the collections activated.
